Google Routing Widget for the Flexviewer
5540
27
03-28-2011 07:05 AM
andrewj_ca
I've just posted a widget for leveraging Google's directions api.  Download and enjoy, both compiled and uncompiled versions have been supplied.  I've posted version 1 of the widget to get some comments and maybe see what additional functionality people may want.  I have my own ideas but I'd like to get some feedback.  Please remember to rate the widget if you like what you see.
http://www.arcgis.com/home/item.html?id=20fc9fd1c43c45c5a1dbf8b4f03bee79
anjelinaponker
Hi
I tested it, but the widget just show text results. the rout don't plot over the base map.
CoryHines
Hi Andrew,
Did this widget get removed from the arcgis site?  It asks for a login but then says I'm not authorized to view the resource.  Just curious, I actually already have everything working except the zoom to route feature.
Thanks for any insight you might have.
Cory
Thanks Mike Don't forget to rate it. I will have an update after I get a few more comments.  I do have zoom to route working.  I will be adding from and to points and tooltips along the route.
ShahSani
I'm trying run the widgets in 3.5 but i am running into an error on geometryService.project([p2 as Geometry], map.spatialReference);
Implicit coercion of a value of type com.esri.ags:SpatialReference to an unrelated type com.esri.ags.tasks.supportClasses:ProjectParameters. GoogleRoutingWidget.mxml
....can someone help me out please.
BjornSvensson
Esri Alum
Sounds like maybe you are using a widget compiled for 2.x with 3.x.  Where did you download this widget (the item mentioned above does not seem accessible any more)?
ShahSani
Yups, i'm using a widget compiled for 2.x with 3.5. just try my luck because i compiled social media widget 2.2 for 3.5 and it's working.I'm download the widget in 2011 (not accessible any more).
BjornSvensson
Esri Alum
If you want to upgrade 2.x code to 3.x, the best starting point (in addition to trying and then interpret error messages), is probably
https://developers.arcgis.com/en/flex/guide/migrating-to-3-x.htm
From that page and related to your error:
On the GeometryService, the input parameter for the project() method is now projectParameters instead of geometries. This also allows for specifying datum transformations (requires ArcGIS 10.1 for Server).
JanieGoddard
Be aware that the old routetasksolver web service is being retired on 12/31/2013.
The North American and European route solvers will be gone after 12/31/2013 per:
http://downloads.esri.com/support/product%20life%20cycle/online_gis/ArcGISOnlineServ_PLC.pdf
Here is the new Route Solver:
http://www.arcgis.com/home/item.html?id=1feb41652c5c4bd2ba5c60df2b4ea2c4
Be aware:
This service is available for users with an ArcGIS Online organizational subscription.  To access this map service, you'll need to sign in with an account that is a member of an organizational subscription.
Heads up!
Janie
JanieGoddard
The new route widget in the above reply does not work in flex viewer 3.0 compiled version. I had to upgrade to flex viewer 3.1 compiled version. Now once the user enters the two addresses, it pops up a signon box. The user must sign in with a userid and password that is a member of an ArcGIS Online organizational subscription.
Good Luck.
Janie
