Export Map Widget for Flex Viewer v3.6 - Missing SWF
2806
01-31-2014 08:04 AM
AaronKreag
Robert-
I just downloaded the latest Export Map Widget for v3.6.  Pointed my Viewer for Flex add new widget to the .zip folder and after a couple seconds I get an Import Custom Widget dialog box that says Custom widget import failed: Could not find widget SWF.  I also deleted all of the files and downloaded a new set just to be sure.  Thanks again for all the great widgets and help!
Kind Regards-
Aaron
RobertScheitlin__GISP
Aaron,
   If this widget was designed to work with app builder than it would have an app builder folder  like my other ones that are designed for app builder. This widget is what is considered a UI Widget and App builder does not support custom UI Widgets.
AaronKreag
Robert,
Ok, thanks for that info.  For some reason I was under the impression that all of your new/updated 3.6 widgets were Viewer for Flex 3.6 upload compatible.  I will pay attention to this in the future.  Thank you!  Aaron
