Google Analytics for Flex 2.5
4385
11
01-31-2012 11:41 PM
JustinGleeson
Hi All,
Just wondering if the Google Analytics widget available here http://www.arcgis.com/home/item.html?id=151491cec5be41b5bb5c81dfe63b1669 works for Flex 2.5? It seems to have been developed for 2.2.
thanks
Justin
TimDine
I'm using the uncompiled widget with 3.3 viewer and it doesn't appear to have any major issues.  I get a few warnings about deprecated functions, but it logs some data to google analytics that I can view.  I'll keep trying it out.  Looks positive.
MLowry
I'd also like to use it for 2.5, but I think 3.0 is being released soonish so maybe they should wait or use the 3.0 beta to develop the new version.
RobertScheitlin__GISP
3.0 API and Viewer will not come out until (or after) ArcGIS Server 10.1 is available.
deleted-user-dbQhBq-o3nyM
Any chance there will be a Google Analytics for Flex version 3.1?
TimDine
KeisukeNozaki
Is there anyone who could compile this widget for 3.3?
AlanIoriati_Colombelli
Hi, I tried compiling for version 3.5 and the following error appears:
  Encountered errors or warnings while building project GoogleAnalyticsWidget.mxml.
    GoogleAnalyticsWidget.mxml: Access of possibly undefined property AppEvent through a reference with static type Class.
    GoogleAnalyticsWidget.mxml: Access of possibly undefined property AppEvent through a reference with static type mx.managers:ISystemManager.
Anyone have idea to solve the problem?
Thanks!
Alan,
   Here are the 3 updated lines of code:
            private function init():void
                //Get the initial parameters from the config file
                if (configXML)
                    gaAccount = configXML.account;
                    logWidgets = configXML.logwidgets == "true";
                    logBasemaps = configXML.logbasemaps == "true";
                    logDrawtools = configXML.logdrawtools == "true";
                //only set listeners if there is an account in the config file
                if (gaAccount != "")
                    tracker = new GATracker( this, gaAccount, "AS3", false );
                    //Log a visit marked as Home page as this will occur when viewer is first opened.
                    tracker.trackPageview( "/" + configXML.flexviewer);
                    AppEvent.addListener(AppEvent.WIDGET_RUN, listenHandler);
                    AppEvent.addListener(AppEvent.BASEMAP_SWITCH, listenHandler);
                    AppEvent.addListener(AppEvent.SET_MAP_ACTION, listenHandler);
                    systemManager.addEventListener(GoogleAnalyticsWidgetEvent.LOG_PAGE, logPageHandler);
Hi Robert,
Thanks for the help, the widget was compiled perfectly with the 3 updated lines of code.
Att,
KeisukeNozaki
Would you mind sharing the compiled widget?
Hi Robert,
Att,
