Getting info from an asset
901
12-21-2012 09:42 AM
MesudKuka
I want to click on an asset (e.g. mains) and get information for it, like info button in ArcMap.
Which gadget should I use in ArcGIS Viewer for Flex 3.1?
Mesud
RobertScheitlin__GISP
Mesud,
   Get the Identify Widget from the code gallery:
http://www.arcgis.com/home/item.html?id=39cf66d58c234279ba728c50461a1a89
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
Mesud,
MesudKuka
Thanks a lot Robert,
Mesud
RhettZufelt
MVP Notable Contributor
Mesud,
If you don't want to have to select the Identify button first, you can configure a popup for that layer:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Pop_up_configuration_files/01m3...
That can give you all the same information the ArcMap identify button does (but is configurable) by just clicking on the feature with the default pointer.
R_
