GeoRSS : XML embedded in aspx page
2709
08-17-2011 09:50 AM
xanderm
I am trying to use a the following feed with the GeoRSS widget without success.  Is there a way to view the embedded xml?
API ref:
http://www.buckeyetraffic.org/services/api/index.html
XML source:
http://www.buckeyetraffic.org/services/RoadActivity.aspx
widget error:
A problem occured while parsing the RSS feed. Error #1009
FaizanTayyab
The paths you provided do not work. Are you using the correct source. Also in code you can use the debugger/trace statements to have a look at the XML that is being retrieved.
xanderm
Interesting. The links work fine for me. I'll continue to debug as much as I can.
RobertScheitlin__GISP
Xander,
   Because your XML does not have rss or atom as the parent xml element the GeoRSSWidget does not know how to parse it.
This is the parent element of a standard rss feed.
<rss version="2.0" xmlns:georss="http://www.georss.org/georss" xmlns:gml="http://www.opengis.net/gml">
xanderm
Thanks, but it's not my feed. Is there a way I can manipulate on the fly or save, edit and serve out locally?
