GeoRSS projection
2745
6
08-04-2011 12:16 PM
CarlAlexander
I am trying to use a GeoRSS feed that seems to be in geographic cooridantes so it will overlay in google maps.  When I try and use this feed in the Flex Viewer it shows the points all over the world.  Is there anything i can do to use this feed in the Flex Viewer?  Thanks.
http://ww2.tdot.state.tn.us/tsw/GeoRSS/TDOTConstructionGeorss.xml
ZahidChaudhry
Simply make an HTTPservice request and then create graphics, reproject graphics to web mercator and display as graphics layer. This will give you more control, like mouse over and which information you want to display or filter. Also, you can try filtering data and custom symbols......
CarlAlexander
Thanks.  I will try this out.  Does ESRI have any documentation on how to do this?
ZahidChaudhry
I dont think so but you can check Adobe's website...they have very good tutorial, how to make an HTTP request...
you can do something like this...
<s:HTTPService id="srv" result="srv_resultHandler(event)" url="here your url"/>
and then in your result handler, you will get an xml back...
  • You can add all data to an arraycollection or use it as such
  • create a map point from lat/long
  • from map point create new graphic, add symbol, attributes
  • Add graphics to graphic layer
  • add graphics layer to the map..
here is a very good video from adobe, I am sure it will be very helpful.
http://www.adobe.com/devnet/flex/videotraining/_jcr_content/bodycontent1/modal_19.content.html' />
CarlAlexander
Thanks.  I will look at videos.  I am not a programmer and was hoping there was a way to use the GeoRSS widget that is provided with the ArcGIS Viewer for Flex.  Thanks again.
RobertScheitlin__GISP
Carl,
   If you have the ability to change code and recompile the viewer than there is a simple fix for this.
Replace the GeoRSSUtil.as code with this:
// Copyright (c) 2010-2011 Esri
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions.  See use restrictions in the file:
// <install location>/License.txt
package com.esri.viewer.utils
    import com.esri.ags.geometry.Geometry;
    import com.esri.ags.geometry.MapPoint;
    import com.esri.ags.geometry.Polygon;
    import com.esri.ags.geometry.Polyline;
    import mx.utils.StringUtil;
    public class GeoRSSUtil
        private static const GEORSS:Namespace = Namespaces.GEORSS_NS;
        private static const GEO:Namespace = Namespaces.GEO_NS;
        private static const GML:Namespace = Namespaces.GML_NS;
        private static const GEOLL:Namespace = Namespaces.GEO_LL;
        public function GeoRSSUtil(singletonEnforcer:SingletonEnforcer)
        public static function toGeometry(x:XML):Geometry
            var georssPoint:String = String(x.GEORSS::point);
            if (georssPoint)
                return parseGeoRSSPoint(georssPoint);
            var georssLine:String = String(x.GEORSS::line);
            if (georssLine)
                return parseGeoRSSLine(georssLine);
            var georssPolygon:String = String(x.GEORSS::polygon);
            if (georssPolygon)
                return parseGeoRSSPolygon(georssPolygon);
            var pointList:XMLList = x.GEO::point;
            if (pointList && pointList.length() > 0)
                var geoPoint:XML = pointList[0];
                var getLat:Number = Number(geoPoint.GEO::lat);
                var geoLon:Number = Number(geoPoint.GEO::long);
                return new MapPoint(geoLon, getLat);
//My Add
            var markerPoint:String = String(x.marker);
            if (markerPoint)
                return parseGeoRSSPoint(markerPoint);
//End My Add
            var whereList:XMLList = x.GEORSS::where;
            if (whereList && whereList.length() > 0)
                var pos:String = whereList[0].GML::Point[0].GML::pos[0];
                var arr:Array = pos.split(" ");
                var gmlLat:Number = Number(arr[0]);
                var gmlLon:Number = Number(arr[1]);
                return new MapPoint(gmlLon, gmlLat);
            var georssLat:String = String(x.GEOLL::lat);
            var georssLong:Number = Number(x.GEOLL::long);
            if ((georssLong) && (georssLat))
                return new MapPoint(Number(georssLong), Number(georssLat));
            return null;
        private static function parseGeoRSSWhere(x:XML):Geometry
            return null;
        private static function parseGeoRSSPoint(text:String):Geometry
            var tokens:Array = StringUtil.trim(text).split(" ");
            var lat:Number = Number(tokens[0]);
            var lon:Number = Number(tokens[1]);
            return new MapPoint(lon, lat);
        private static function parseGeoRSSLine(text:String):Geometry
            var path:Array = [];
            if (tokens.length > 3)
                for (var i:int = 0, j:int = 1; j < tokens.length; i += 2, j += 2)
                    var lat:Number = Number(tokens);
                    var lon:Number = Number(tokens);
                    path.push(new MapPoint(lon, lat));
            return new Polyline([ path ]);
        private static function parseGeoRSSPolygon(text:String):Geometry
            return new Polygon([ path ]);
class SingletonEnforcer
CarlAlexander
Robert, this worked perferct.  Thanks.
