Focus cursor in widget text boxes
2314
07-12-2012 09:53 AM
AndrewEdmonds
How do you focus the cursor in widgets with text boxes?  Specifically, I am thinking of the Locate, Print, Query, and Search (and eSearch, by extension) widgets.  It's an unnecessary extra click when opening these widgets.  I'm not a programmer, but I'm guessing that a solution requires digging into the uncompiled code?
RobertScheitlin__GISP
Andrew,
   First let me point out that you should post Flex Viewer/Widget Questions to the Flex Viewer forum here:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
Yes this would require changing the uncompiled code and setting the focus on the textbox for each of these widgets. The TextInput has a setFocus method.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Andrew,
