Flexviewer Logo Not Showing
1955
5
08-25-2011 04:23 AM
AndyWhitley
I have a department logo that is not showing up on our flex site.  It shows up when I run the project in flash builder but not after the release build is created.  Any suggestions?
MLowry
Have you checked to make sure said image is in assets/images of the bin-release build?
AndyWhitley
I will double check that....thanks
AndyWhitley
I am still having an issue that my department logo will not show up.  Any suggestions?  I have double checked the path and file name and everything looks fine.
MLowry
Are you referring to the logo in the headercontroller widget? The logo to the left of the title and subtitle?
Have you tried multiple browsers? Have you tried directly accessing the image path through the URL address where it's located on the server? What's the size of the image and type of image? Can you post your headercontrollerwidget.xml?
AndyWhitley
Yes, I am referring to that logo, sorry about that.  I checked the HeaderControl Widget and it still had globe.png......
