Flex Viewer with Linux web server
1036
03-20-2014 09:50 AM
MikeFrey
I am fairly new to creating web services but I created an application using Flex API locally on IIS. Our company's web server host is off site and uses a Linux based server. Will the application built with IIS work on this web server? and will the web adaptor work on the Linux server?
Thanks
GISDev1
Thanks
Yes and yes.
Keep in mind that IIS is not case-sensitive and most popular Linux Web Servers are case-sensitive, so be careful on that part. Also, if you happen to be using a Proxy in IIS, that will likely need to be re-done for the Linux Web Server.
GISDev1
Thanks
Yes and yes.
