Flex Viewer - Popup Config for Image Hyperlink
2851
03-08-2013 08:38 PM
ShaunWeston
I'm trying to embed an image in the description tag like so:
    <description>
    <![CDATA[
Total Rates ($): {TotalRates}
Hectares: {Hectares}
<B><a href="{NCSURL}" target="_blank">Further Rates Information</B>
<img src="assets/images/NCSlogo.PNG" alt="NCS" height="30" width="80"/></a>
    </description>
So this works, but what I'm wanting to do is make the image clickable and go to the hyperlink, however the above doesn't work for some reason. I've got it working with another widget I made, but this config doesn't work for some reason? It works for the text, just not the image?
BjornSvensson
Esri Alum
It might be picky on your tag closing order. Try removing your bold tags, or at least move the closing bold tag to after the closing A tag (since you started the bold before the A).
BjornSvensson
Esri Alum
ShaunWeston
Yeah cheers, I changed it to this:
<a href="{NCSURL}" target="_blank"><B>Further Rates Information</B>
and it works slightly better, but still not quite right. It will do for now.
