Flex Viewer Chart Widget - Share Chart results with Attribute Widget
2212
04-10-2013 05:20 AM
JasonLee1
I am looking for a way to modified the chart widget 3.2 to share the results of a selection so that the selection set is shown in the attribute widget just like the query and search widget does if your you add the tag shareresults to be true. I know that the chart produces a hidden layer, so I can change the code and modify the feature layer name and remove the hiddenLayer_
<esri:FeatureLayer id="highlightFeatureLayer" name="hiddenLayer_chartWidgetSelectionLayer"
this will allow the layer to be added to the attribute table, but I also need a way to get the outfields to show up. Any ideas?
