Feature Tooltip Widget
2702
06-06-2011 12:06 PM
LarryJahn
I am trying to use the Feature Tooltip Widget but cannot get it to work.
Here is my FeaturetooltipWidget.xml:
<?xml version="1.0" ?>
<configuration>
<layers>
        <layer>
            <name>Projects</name>
            <fields>PROJID,DESCRIPT,OTHER_INFO,CLIENT,CONTACT,MANAGR</fields>
        </layer>
    </layers>
</configuration>
I placed the following under the "UI Elements" in my config.xml:
<widget left="0" top="0"       config="widgets/FeatureTooltip/FeatureTooltipWidget.xml" url="widgets/FeatureTooltip/FeatureTooltipWidget.swf"/>
I am using ArcGIS Viewer for Flex 2.3.1.  What am I missing?  Thanks
RobertScheitlin__GISP
Larry,
   Is projects the label of the layer as it appears in the config.xml and is the layer type="feature"?
LarryJahn
There's my problem.  My layer is "dynamic", not "feature".  Is there an easy way to get your tool to work with a dynamic data set?
Larry,
   Nope, this widget is only designed for a feature.
LarryJahn
Thanks, Robert.  I appreciate all of your contributions.
