Feature Layer Tips (map tips)
2058
9
06-30-2011 05:03 AM
PaulLang
Is it possible to set/change the time limit to the mouse-over tips?
Currently it???s only a few seconds I would like to extend this time.
Great job Robert!
RobertScheitlin__GISP
Paul,
  Version 2.3.1.1 now has this feature configurable.
JoshJones1
Hello.
I was curious if anybody had a compiled version of the Feature Layer Tips (map tips) that was compatible with Flex Viewer 2.4.  I'm not currently going to be switching over to 2.5, and have no idea when (or if) I am going to be switching over to 2.5.
If anybody has one of these I would greatly appreciate the help.
Thanks.
-Josh
Josh,
    Here is the 2.4 version.
I am always curious as to why individuals do not update to the latest version of the viewer (being free and all). Care to share why you are delaying or are undecided if you even will update?
JoshJones1
Thanks Robert.
I am not able to make my own widgets, or even edit the existing the .swf of existing widgets, as I have no experience in Flash Builder whatsoever and my current position does not allow me the time to learn it.  I have had a couple of widgets that were built for me by people who knew what they were doing that operate only in 2.4, so this is what I am currently using.  I actually had to upgrade to 2.4 because the last widget that was built didn't work in 2.3.
Works for me for now I guess.
Thanks again Robert.
-Josh
ChristinaMcCullough
Thank you for posting your 2.4 version of this widget.
ChristinaMcCullough
I am working with several versions due to the client's need for a specific widget.  Some are not willing to move up t the next version because they use a widget for their daily operations.  It would be ideal if all the widgets created by the community would still be available.
Erickson_Contract_Surveying_
Is it possible to display a clickable URL within the tip?
Derek,
   Nope the feature tool tip is for simple text. If you need that level of complexity then use popups.
RayCrew
There are many organizations which do not allow any updates without first doing a security review. I have even seen things a like an update to virus definitions or a critical security patch for Windows have to go through a security review first. Crazy? Yes.
