ESRI basemaps display scales
2501
05-20-2013 10:54 AM
JustinNettleton
I am just curious if there is a way to only have ESRI basemaps turn on at a certain scale? My map opens up at the 577,xxx scale, but don't want the imagery to turn on until I get moved in closer. Is there any way to do this using the basic Flexviewer application?
RobertScheitlin__GISP
Justin,
   Every layer element in the viewers main config.xml has a minscale and maxscale attribute that you can use.
Documentation Here:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Layer_tag_overview/01m30000000p...
Justin,
Documentation Here:
MayJeff
Take a look on this:
http://forums.arcgis.com/threads/83035-defining-zoom-level-with-basemaps?highlight=lods
I set lods for my basemap and it works.  Thanks.
JustinNettleton
Should have known that, thanks Robert.
