eSearch Widget - Initial search from URL parameters
4014
5
03-06-2014 09:16 AM
JordanBaumgardner
My client has a requirement to use urls like MyFlexViewer.html?search=12345 and have it search for 1235 and zoom to it. (their old version did this, and use the 1st search term to make it happen)
I've seen several treads from the 2.x days showing how to add the code to do that. But also see many comments about 3.6 handling this nicely - the notes say "See instructions" - But... I can't seem to find them. I have read the config.pdf but didn't see it. I took a peek at the code, but found nothing.
Thanks in advance.
RobertScheitlin__GISP
Jordan,
   Wrong PDF. Look in this one:
Enhanced Search Widget URL Search Configuration.pdf 😉
Jordan,
   Did you look in the Enhanced Search Widget URL Search Configuration.pdf
It gives examples:
http://gislap134/FlexViewer2.1/index.html?esearch=R1&slayer=0&exprnum=0&showdatagrid=true
JordanBaumgardner
Ya, just looked again in Enhanced Search Widget XML Configuration Page*1*of*13* * Developed*By:*Robert*Scheitlin*Version 3.6.4 �?? Mar 3, 2014
But could not see any example with eserach= or search=. I swear I read it ; )
But lets just take this appart:
-- esearch=R1 where r1 is the <layer><name>?
-- slayer=0 where 0 is the layer #? but isn't that specified in the <layer><url> as in http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/M...
-- exprnum=0 where 0 is the string to search for?
-- Showdatagird=true - self explanatory.
I'm using the following pdf:
https://raw.github.com/rscheitlin/eSearch/master/Enhanced%20Search%20Widget%20XML%20Configuration.pd...
Jordan,
JordanBaumgardner
Ahhhh, thank you! And my client thanks you too!
JordanBaumgardner
