Esearch Widget 2.5 question
2396
08-23-2012 06:51 AM
AimeiChen
I recently upgraded my ArcGIS Server to 10.1 and then migrated my flex project to 2.5, everything looks good except the esearch widget had some issues. It works on some layers but not all of them. I kept getting an error
"[RPC Fault faultString="Invalid or missing input parameters." faultCode="400" faultDetail=""]
I compared the syntax in the searchwidget.xml, can't find any difference between the ones working and the ones not working. I have some examples below, Search for "Premises" fine but can't search for "Storm Sewers".
<layer>
           <definitionexpression></definitionexpression>
           <enableexport>true</enableexport>
            <name>CWW/MSD/SMU Premises</name>
            <url>http://gisserver-10:6080/arcgis/rest/services/MSD/SearchFeature/MapServer/42</url>
            <expressions>
             <expression alias="Premise ID" textsearchlabel="Search by partial of premise ID.[Example:1311.]" >PREM LIKE ('[value]%')</expression>
             <expression alias="Customer Name" textsearchlabel="Search by Customer's First Name.[Example:kyle.]" >CUST_NAME LIKE upper ('[value]%')</expression>
             <expression alias="Parcel ID" textsearchlabel="Search by full Parcel ID.[Example:013400030356.]" >PARCELID = ('[value]')</expression>
             <expression alias="Branch No." textsearchlabel="Search by full branch No..[Example:300936.]" >BR_NUMBER = ('[value]')</expression>
            </expressions>
            <graphicalsearchlabel>Use one of the graphical search tools to select Premises.</graphicalsearchlabel>
   <titlefield>CUST_NAME</titlefield>
            <linkfield></linkfield>
   <icon isfield="true" iconprefix="" iconsuffix=""></icon>
            <fields all="false">
              <field name="PREM" alias="Premise ID" gridfield="true"/>
              <field name="CUST" alias="Customer ID" gridfield="true"/>
              <field name="CUST_NAME" alias="Customer Name" gridfield="true"/>
              <field name="SERV" alias="Service ID" gridfield="true" gridfieldonly="true"/>
              <field name="S_STAT" alias="Service Status" gridfield="true" gridfieldonly="true"/>
              <field name="HOUSE" alias="House No." gridfield="true"/>
              <field name="STREET" alias="Street Name" gridfield="true"/>
              <field name="BR_NUMBER" alias="Branch Number" gridfield="true" gridfieldonly="true"/>
              <field name="BR_SIZE" alias="Branch Size" gridfield="true" gridfieldonly="true"/>
            </fields>
            <floatorfixed>fixed</floatorfixed>
            <autoopendatagrid>true</autoopendatagrid>
            <zoomscale usegeometry="true" zoompercent="1.6">1200</zoomscale>
        </layer>
        <layer>
<name>Cincinnati Storm Sewers</name>
<url>http://gisserver-10:6080/arcgis/rest/services/MSD/SearchFeature/MapServer/3</url>
<expressions>
<expression alias="Segment ID" textsearchlabel="Search by partial of Segment ID.[ Example:337012003 ]:">SEG_ID LIKE '%[value]%'</expression>
</expressions>
<graphicalsearchlabel>Use one of the graphical search tools to select Cincinnati Storm Sewers</graphicalsearchlabel>
<spatialsearchlayer>true</spatialsearchlayer>
<titlefield>SEG_ID</titlefield>
              <field name="SEG_ID" alias="Segment ID" gridfield="true"/>
              <field name="PIPE_SIZE" alias="Pipe Size" gridfield="true"/>
              <field name="SEW_SHAPE" alias="Sewer Shape" gridfield="true"/>
              <field name="MATERIAL" alias="Material" gridfield="true"/>
              <field name="REC_DIST" alias="Segment Length" gridfield="true" sum="true" sumlabel="Total length" numberformat="2|,|."/>
              <field name="UP_INV" alias="Upstream Inv" gridfield="true" numberformat="2|,|."/>
              <field name="DN_INV" alias="Downstream Inv" gridfield="true" numberformat="2|,|."/>
              <field name="SLOPE" alias="Slope" gridfield="true" numberformat="2|,|."/>
              <field name="PUB_PRI" alias="Pub/Pri" gridfield="true"/>
              <field name="HEIGHT" alias="Height" gridfield="true"/>
              <field name="WIDTH" alias="Width" gridfield="true"/>
              <field name="PTYPE" alias="Pipe Type" gridfield="true"/>
              <field name="DSTNTN" alias="Flow Destination" gridfield="true"/>
              <field name="OWN_VER" alias="Owner Verification" gridfield="true"/>
              <field name="MEAS_REF" alias="Measure Reference" gridfield="true"/>
            </fields>
            <floatorfixed></floatorfixed>
   <icon isfield="true"></icon>
   <zoomscale usegeometry="false">2400</zoomscale>
     </layer>
Please help me to figure it out what's wrong here. Thanks
Amy
RobertScheitlin__GISP
Aimei,
   So are you saying that this exact layer configuration (minus the new url) worked in 2.5 using AGS Server 10 or less but now does not work in 10.1?
AimeiChen
Aimei,
Yes, I think so. I searched in the forum, there are somebody else had the same issue recently.
Aimei,
   All I can tell you then is to try the search using that expression on the REST Service directory end point page and see if it has an problems.
RhettZufelt
MVP Notable Contributor
<layer>
<expressions>
<expression alias="Segment ID" textsearchlabel="Search by partial of Segment ID.[ Example:337012003 ]:">SEG_ID LIKE   '%[value]%  '</expression>
</expressions>
Amy
If this is a numeric field as your "Example text" states, you need to remove the single quotes as this passes it as a text expression.
Also, do not believe LIKE works with numeric fields anyway.
might try:
<expression alias="Segment ID" textsearchlabel="Search by partial of Segment ID.[ Example:337012003 ]:">SEG_ID = [value]</expression>
R_
