eSearch+RPC Fault faultString error
5721
21
10-14-2012 11:47 PM
anjelinaponker
I,m using "eSearch" widget in Flex 3 and Arc GIS Server 10.1, but when I want to make a buffer it return this error:
[RPC Fault faultString="Invalid or missing input parameters." faultCode="400" faultDetail="the input is not a geographic or projected coordinate system"]
what is the reason of this error?
anjelinaponker
Anjelina,
   So when you click yes you do not recieve another dialog that asks you where you want to save the file? Is it possible that it is poping up behind another window?
No no
I recieve another dialog and I select destination folder but it can not download output.zip from arcgisjob folder and it dont save any thing.
JordanBaumgardner
Folks, I'm having the same issue after an upgrade to 3.6
(after reading this thread I changed spatialreference to: <spatialreference>102100</spatialreference> ) but that did not help.
There is one query that worked (of course) in the old version and no longer works with my upgrade. I'm receiving the same error: Invalid or missing input parameters.
The table in question used to be in a <layer> tag, but it is not a feature class, and my understanding is that it should be moved to a <table> tag.
Of course the sample queries work great.
I'm beginning to think I need to set something up on the service itself, but I can't think of what that would be.
Here is my config entry:
Thank you in advance
  <table>
   <name>Customers</name>
   <token/>
   <definitionexpression></definitionexpression>
   <enableexport>true</enableexport>
   <url>http://gisweb:6080/arcgis/rest/services/detailed/MapServer/84</url>
   <expressions>
    <expression alias="Location Code" textsearchlabel="Search Service by Location Code [ Example: 232410901 ]:" isvaluerequired="true">
     <values>
      <value prompt="Example: 232410901" isvaluerequired="true" >xx.METER.LOCATION_CODE = '[value]'</value>
     </values>
    </expression>
    <expression alias="Customer Name" textsearchlabel="Search Customer by Customer Name [ Example: FROST ]:" isvaluerequired="true">
     <values>
      <value prompt="Example: FROST" isvaluerequired="true" >upper(xx.METER.CUSTOMER_NAME) LIKE upper('[value]%')</value>
     </values>
    </expression>
    <expression alias="Billing Acct #" textsearchlabel="Search Customer by Account # [ Example: 487788 ]:" isvaluerequired="true">
     <values>
      <value prompt="Example: 487788" isvaluerequired="true" >xx.METER.ACCOUNT_NUMBER = '[value]'</value>
     </values>
    </expression>
    <expression alias="Service Street Address" textsearchlabel="Search Customer by Street Address [ Example: 850 COMMERCE RD ]:" isvaluerequired="true">
     <values>
      <value prompt="Example: 850 COMMERCE RD" isvaluerequired="true" >upper(xx.METER.SERVICE_ADDRESS_1) = upper('[value]')</value>
     </values>
    </expression>
   </expressions>
   <titlefield>xx.METER.CUSTOMER_NAME</titlefield>
   <fields all="false">
    <field name="xx.METER.LOCATION_CODE"/>
    <field name="xx.METER.ACCOUNT_NUMBER" gridfield="true" />
    <field name="xx.METER.CUSTOMER_NAME" gridfield="true" />
    <field name="xx.METER.SERVICE_ADDRESS_1" gridfield="true" />
    <field name="xx.METER.SERVICE_ADDRESS_2" gridfield="true" />
    <field name="xx.METER.SERVICE_CITY_STATE_ZIP" gridfield="true" />
    <field name="xx.METER.HOME_PHONE" gridfield="true" />
    <field name="xx.METER.ACCOUNT_STATUS" gridfield="true" />
   </fields>
   <links/>
  </table>
Table in question:
Layer: xx.METER (ID: 84)
Display Field: CUSTOMER_NAME
Type: Table
Geometry Type: N/A
Description: null
Definition Expression:
Copyright Text: N/A
Default Visibility: false
MaxRecordCount: 1000
Supported Query Formats: JSON, AMF
Supports Advanced Queries: true
Supports Statistics: true
Extent:
Drawing Info:
N/A
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeNone
Type ID Field: null
Fields:
OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID )
LOCATION_CODE ( type: esriFieldTypeString , alias: Location Code , length: 30 )
METER_NUMBER ( type: esriFieldTypeString , alias: Meter Number , length: 30 )
CUSTOMER_NAME ( type: esriFieldTypeString , alias: Customer Name , length: 40 )
ACCOUNT_NUMBER ( type: esriFieldTypeString , alias: Account Number , length: 20 )
ACCOUNT_STATUS ( type: esriFieldTypeString , alias: Account Status , length: 10 )
BILLING_ADDRESS_1 ( type: esriFieldTypeString , alias: Billing Address 1 , length: 40 )
BILLING_ADDRESS_2 ( type: esriFieldTypeString , alias: Billing Address 2 , length: 40 )
BILLING_CITY_STATE_ZIP ( type: esriFieldTypeString , alias: Billing City, State, Zip , length: 40 )
SERVICE_DESC ( type: esriFieldTypeString , alias: Service Description , length: 40 )
SERVICE_ADDRESS_1 ( type: esriFieldTypeString , alias: Service Address 1 , length: 40 )
SERVICE_ADDRESS_2 ( type: esriFieldTypeString , alias: Service Address 2 , length: 40 )
SERVICE_CITY_STATE_ZIP ( type: esriFieldTypeString , alias: Service City, State, Zip , length: 40 )
HOME_PHONE ( type: esriFieldTypeString , alias: Home Phone Number , length: 40 )
SUBDIVISION ( type: esriFieldTypeString , alias: SUBDIVISION , length: 40 )
BLOCK_NUMBER ( type: esriFieldTypeString , alias: Block Number , length: 10 )
LOT_NUMBER ( type: esriFieldTypeString , alias: Lot Number , length: 10 )
APARTMENT ( type: esriFieldTypeString , alias: Apartment Number , length: 10 )
SUITE ( type: esriFieldTypeString , alias: Suite Number , length: 10 )
ON_DATE ( type: esriFieldTypeDate , alias: ON_DATE , length: 36 )
SECTION_ID ( type: esriFieldTypeString , alias: Line Section ID , length: 20 )
PRIMARY_METER ( type: esriFieldTypeString , alias: Primary Meter? , length: 1 , Coded Values:  ,  )
SERVICE_LOCATION_ID ( type: esriFieldTypeInteger , alias: Service Location ID (Foreign Key) )
CAYENTA_LOC_REC_NO ( type: esriFieldTypeString , alias: CAYENTA_LOC_REC_NO , length: 20 )
ROUTE_NO ( type: esriFieldTypeString , alias: Route No , length: 10 )
SEQ_NO ( type: esriFieldTypeString , alias: Sequence No , length: 10 )
CYCLE_NO ( type: esriFieldTypeString , alias: Cycle No , length: 10 )
JDE_WO_ID ( type: esriFieldTypeString , alias: JDE_WO_ID , length: 20 )
DATE_INSERVICE ( type: esriFieldTypeDate , alias: Date Inservice , length: 36 )
WIRE_COUNT ( type: esriFieldTypeInteger , alias: Wire Count )
SERVICE_STATUS ( type: esriFieldTypeString , alias: Service Status , length: 10 )
LOCATION_CLASS ( type: esriFieldTypeString , alias: Location Class , length: 10 )
LOCATION_SUBCLASS ( type: esriFieldTypeString , alias: Location Subclass , length: 10 )
METER_BILL_CODE ( type: esriFieldTypeString , alias: Meter Bill Code , length: 10 )
KW_DEMAND ( type: esriFieldTypeString , alias: KW Demand , length: 20 )
KWH_CONSUMED ( type: esriFieldTypeString , alias: KWH Consumed , length: 20 )
READ_DATE ( type: esriFieldTypeDate , alias: Read Date , length: 36 )
BILLING_CYCLE_DAYS ( type: esriFieldTypeString , alias: Billing Cycle Days , length: 10 )
CRITICAL_LOAD ( type: esriFieldTypeString , alias: Critical Load , length: 7 )
SPOT_LOAD ( type: esriFieldTypeString , alias: Spot Load , length: 5 , Coded Values:  ,  )
METER_TYPE ( type: esriFieldTypeString , alias: Meter Type , length: 15 )
METER_MULTIPLIER ( type: esriFieldTypeString , alias: Meter Multiplier , length: 5 )
TAX_DISTRICT ( type: esriFieldTypeString , alias: Tax District , length: 5 )
METER_COMMENTS ( type: esriFieldTypeString , alias: Meter Comments , length: 100 )
WORKREQUESTID ( type: esriFieldTypeString , alias: Work Request ID , length: 20 )
DESIGNID ( type: esriFieldTypeString , alias: Design ID , length: 20 )
WORKLOCATIONID ( type: esriFieldTypeString , alias: Work Location ID , length: 20 )
WORKFLOWSTATUS ( type: esriFieldTypeInteger , alias: Work Flow Status , Coded Values: [0: None] , [1: In Design] , [2: Pending Approval] , ...5 more... )
WORKFUNCTION ( type: esriFieldTypeInteger , alias: Work Function , Coded Values: [0: In-Service] , [1: Install] , [2: Remove] , ...5 more... )
HOUSE_NO ( type: esriFieldTypeString , alias: House Number , length: 18 )
STREET_PFX_DIR ( type: esriFieldTypeString , alias: Street Prefix Direction , length: 5 , Coded Values:  ,  , [NE: North East] , ...5 more... )
STREET_NM ( type: esriFieldTypeString , alias: Street Name , length: 40 )
STREET_NM_SFX ( type: esriFieldTypeString , alias: Street Name Suffix , length: 6 , Coded Values: [ALY: Alley] , [ANX: Annex] , [ARC: Arcade] , ...196 more... )
STREET_SFX_DIR ( type: esriFieldTypeString , alias: Street Suffix Direction , length: 5 , Coded Values:  ,  , [NE: North East] , ...5 more... )
SEC_ADDR_ID ( type: esriFieldTypeString , alias: Secondary Address (unit) , length: 5 , Coded Values: [APT: Apartment] , [BLDG: Building] , [BOX: Box] , ...12 more... )
SEC_ADDR_RANGE ( type: esriFieldTypeString , alias: Secondary Address Range , length: 18 )
SPECIAL_DIRECTIONS ( type: esriFieldTypeString , alias: Special Directions , length: 50 )
BAD_DOG ( type: esriFieldTypeString , alias: Bad Dog , length: 10 )
TECH_SERV_MULTIPLIER ( type: esriFieldTypeString , alias: Tech Services Multiplier , length: 10 )
FLEXNET_ID ( type: esriFieldTypeString , alias: FLEXNET_ID , length: 20 )
Relationships:
Service Location (0) -- Related To: De-Energized Service Locations (8)
Supported Operations:   Query   Query Related Records   Generate Renderer   Return Updates
