eSearch question: Hit enter when searching multiple attributes
1181
11-07-2012 07:14 AM
BrianFausel
I am using the recent eSearch widget v 3.013 in the 3.0 Flex Viewer.  How challenging would it be to modify it to allow a user to hit enter (rather than click the Search button) once they fill in their search strings for two or more attributes?  I know Robert removed this capability for a reason (see link below), but I figured I would ask.  Any guidance would be greatly appreciated, especially if written for someone with limited Flex programming experience.  I have deployed the viewer and widget via the source code and have access to Flash Builder.
Thanks to Robert for the great tools he has developed and supported over the years!
Robert???s response about this request:
http://forums.arcgis.com/threads/60812-Enhanced-Search-Widget-Searching-Multiple-Fields?highlight=es...
RobertScheitlin__GISP
Brian,
   Actually after thinking about it for a minute... Here is the solution:
            /*              * when a value triggers a submit such as when Enter is pressed in text box             * perform the search             */             private function onSearchSubmitted(evt:Event):void             {                             if(searchGroup.numElements == 1){                     equeryFeaturesText(null);                 }else{                     //If the search is valid then the searchBtn is enabled                     if(searchBtn.enabled){                         equeryFeaturesText(null);                     };                 };             }
Brian,
   I can point you to where you would insert code that verifies that the inputs are valid and then does the search:
                // TODO: validate here?
                // if single value, then automatically submit
                // TODO: if >1 value and all are valid, then submit
Brian,
BrianFausel
That did the trick, thanks for the quick response!
