eSearch graphical search error 1009
3078
10-20-2014 03:27 AM
ArnauForner
Hello,
When I search for features (points) using the eSearch widget I get the correct results in the widget, but I don't get the Features Selected number. Instead it says error #1009 (see image). This only happens with the Graphical Search. When I use the Text Search I get the Features Selected number correct. In addition, if I first use the Text Search and later I use the Graphical Search then I don't get the error. Any suggestions?
I am using version 3.6.9
Arnau
RobertScheitlin__GISP
Arnau,
   Version 3.6.10 is now available and addresses this issue.
AnthonyGiles
Honored Contributor
Arnau,
make sure you have your objectid and your shape fields turned on in your layers.
regards
Anthony
ArnauForner
Anthony,
Both the shape and the objectid field are turned on in my layer.
regards,
Arnau
Arnau,
   Thanks for reporting this I will have it fixed today and release a new version.
Arnau,
ArnauForner
Thanks Robert!
For addressing the issue and also for the speed
Great
Arnau
