eSearch 3.0 graphics not visible
806
07-23-2012 11:33 AM
EricGardecki
I have been working on getting my 2.5 application up on flexviewer 3.0 but found an issue and I'm not sure what is going on.  When using the enhanced search widget graphical search function, the graphics are not visible.  I'm still able to search on where those graphics should be but the actual graphic itself no longer appears like it did in 2.5.  I've tried using both the compiled and uncompiled version of the widget.
Any ideas what might be wrong?   I'm using AGS 10.0, flash 11.3, and tried multiple browsers just in case.
Thanks!
RobertScheitlin__GISP
Eric,
   I guess in some testing I commented out the lines where I add the graphics layers for the graphical search and the buffering.
So find these line in the SearchWidget.mxml and uncomment them.
map.addLayer(graGraphicsLayer); map.addLayer(graphicsLayerBuffer);
I will get this fixed in the next release.
Eric,
EricGardecki
That did the trick.  Thanks
