Error on Link Widget
1531
10-05-2011 09:00 AM
BrunoPereira1
I'm tryin to use Link Widget, but I get a Error:
the method addListener does exists (AppEvent.addListener).
Call to a possibly undefined method addListener through a reference with static type Class.
I'm using SDK 4.1 and Flex version 10.0.
What is the error?
Thanks!
RobertScheitlin__GISP
Bruno,
   You would only be getting this error if you are attempting to use this Flex Viewer 2.4 widget in an earlier version.
BrunoPereira1
My mistake! I'm sorry,
But you have examples to use the same functionality in version 2.2?
Thanks!
Bruno,
Bruno,
  Try changing this line:
AppEvent.addListener(AppEvent.WIDGET_RUN, checkIfLinkWidget);
To this:
ViewerContainer.addEventListener(AppEvent.WIDGET_RUN, checkIfLinkWidget);
BrunoPereira1
Robert, Thanks Again, One more time, once again, over again 😄
Bruno,
To this:
