Error loading KML just started yesterday.
6306
6
05-08-2013 07:23 AM
MartynSmith
I have a flex viewer app that displays a set of regularly updated KML files that I've been maintaining for over a year without issue.  Yesterday I began getting the following error message:
[ATTACH=CONFIG]24132[/ATTACH]
Viewing the NET tab in firebug I can see the request for the KML going out via:
http://utility.arcgis.com/sharing/kml?outSR=4326&url=http://ny.water.usgs.gov/projects/eom/data/2013...
The KML exists on the server and is public and you can verify it by download.  The error getting thrown by this URL is:
{"error":{"code":400,"message":"File not found. Wrong url or out of memory.","details":[]}}
Thanks for any help getting to the bottom of this
GISDev1
Not sure if it helps, but I get the exact same error message in my browser when I request that URL.
Oh, check it out. here's a new error:
{"error":{"code":400,"message":"Internal kml parser error.","details":["The element type \"table\" must be terminated by the matching end-tag \"<\/table>\"."]}}
To get the new error I went to: http://utility.arcgis.com/sharing/kml
And put in your KML link as the parameter. And that's the error I got above.
MartynSmith
Thanks, oddly I'm still getting the same error, no mention of a missing tag.  This viewer has been working fine for about a year and a half, can someone at ESRI tell me if something just changed?
AnthonyGiles
Honored Contributor
Martyn,
I have just taken a copy of the file and placed it in my public area of my dropbox account and it works ok:
http://utility.arcgis.com/sharing/kml?outSR=4326&url=https://dl.dropboxusercontent.com/u/25829160/Ap...
not sure whats happening with the service
regards
Anthony
MartynSmith
Thanks for your help... I just tried your URL and it worked, then I refreshed and got a different timeout error.  The KML file is 52k so I'm not sure how file size can be a problem:
{"error":{"code":400,"message":"Processing time out(current limit is 30000 milliseconds). File so big and/or not enough resources.","details":[]}}
ESRI?
MartynSmith
Turns out this was a USGS/ Amazon EC2 ISP issue.  It has just been resolved.  Thanks
GISDev1
On esri's side or your side?
