Error in Export2Shp widget updated to V3.0
1123
07-05-2012 07:30 AM
ShaningYu
Honored Contributor
I tried to update Export2Shp widget from V2.5 to 3.0. I received such an error
Description Resource Path Location Type
1119: Access of possibly undefined property id through a reference with static type com.esri.ags.layers.supportClasses:LayerInfo. Export2ShpWidget.mxml /Flexviewer_Butler/src/widgets/Export2Shp line 174 Flex Problem
url = (svc as ArcGISDynamicMapServiceLayer).url + "/" + (layerDdl.selectedItem as LayerInfo).id;
A red-line is under 'id'.
How to solve this problem? Thanks.
BjornSvensson
Esri Alum
BjornSvensson
Esri Alum
The id property in LayerInfo has been renamed layerId.
See the migration doc at http://resources.arcgis.com/en/help/flex-api/concepts/index.html#/Migrating_from_2_5_to_3_0/017p0000...
ShaningYu
Honored Contributor
Change .id to layerId.  Thanks.
