Error - Highlight polygon when item roll over on datagrid
1725
01-17-2013 08:24 AM
by Anonymous User
Not applicable
Original User: MayMay
I try to highlight a polygon when item roll over on the datagrid and unhighlight it when item roll out.  But keep getting error message on onItemRollOut function.
I attached the modify code and message here.  Hope someone can give me so ideas.
Thank you.
RobertScheitlin__GISP
May Jeff,
   Is the item renderer null? Your a developer right? You should be able to debug what item is null.
by Anonymous User
Not applicable
Original User: rscheitlin
May Jeff,
  What is it that is null?
by Anonymous User
Not applicable
Error message show up if I add following line to onItemRollOut function.
findGraphicByAttribute(event.itemRenderer.data.oid).symbol = resultsSymbol;
Do you know any other way try to highlight polygon on datagrid when item roll over?
Thank you.
May Jeff,
