ERROR: Enhanced Search Widget version 2.3
779
08-25-2011 05:11 AM
xanderm
on our public sites we are seeing the following error when using the widget (e.g. graphical search).
[RPC Fault faultString="Error #2048" faultCode="null" faultDetail="null"] ... [RPC Fault faultString="Error #2048" faultCode="null" faultDetail="null"]
The layers are drawing , pop-ups work, etc.
www.clevelandgis.org/pub/index.html?config=accela.xml
RobertScheitlin__GISP
Xander,
   If you use fiddler it show you that it is failing to get the crossdomain.xml from the server
http://maps.clevelandgis.net/crossdomain.xml
xanderm
http://maps.clevelandgis.net/crossdomain.xml is our internal server.
I have a crossdomain file in http://www.clevelandgis.org/crossdomain.xml
Why is it looking at my internal server? It is where the swf was created.
xanderm
any other thoughts on this?
Xander,
    Is this the first time you are using your reverse proxy? It seems like that is what your server configuration is. If that is the case than you need to be using your external servers name in your config.xml so that the proxy passes the right url. This is a server configuration issue that you can call tech support for.
