Error: "bin-debug/index.html" not found (ArcGIS Viewer for Flex3.0/Flash Builder 4.6)
2531
08-17-2012 12:38 PM
HakimAbdi
Hello everyone,
I'm giving a try at compiling the latest version of ArcGIS Viewer for Flex. I downloaded the source code for ArcGIS Viewer for Flex 3.0 and tried to compile it with Flash Builder 4.6. I've been following the steps in (http://help.arcgis.com/en/webapps/flexviewer/help/index.html#//01m30000001q000000). I selected the default SDK (currently "Flex 4.6.0").
Everything goes well until I try to verify the setup of the Viewer by running it. The instructions say that a browser window will open and the Flexviewer application will be displayed but I first get an vague error message stating "Errors exist in required project(s): FlexViewer. Proceed with launch?". I hit "Proceed" and I get a "Launch Failed" window that says "File not found: file:/C:/flashbuilder46/FlexViewer3/bin-debug/index.html". I scoured the internet but I've been unable to find a solution. This is a similar issue to (http://forums.arcgis.com/threads/19823-Starting-the-Flex-Viewer-2.2-from-Flex-Builder), the only difference is that my html-template folder is present in my FlexViewer3 directory.
Any help in solving this is greatly appreciated.
Cheers,
Hakim
HakimAbdi
I've figured out what the problem was. There were some files missing in the "src" directory so I copied the everything over and that worked. Please disregard this inquiry.
HakimAbdi
RobHawkins
I'm afraid I am also getting this: and would love to know what files were missing
JohnDriessen1
I'm also receiving this error using Flex 3.4  Where can I find a copy of the missing index.html file?  I've tried re-downloading several times and even trying Flex 3.3 API and still get the same error.
