Error #2036 load never completed, please help!
2960
03-28-2012 08:48 AM
MartynSmith
I'm getting the 2036 error when clicking the layer list widget.  I know this can be caused by a typo in a path, but I have verified the paths in my config.xml many times and I'm sure they are correct.  The widget works without error when I run the debug version on my local computer thru IIS, I only get the error when I copy the release build to the production server.
Full error message using internet explorer is:
Error #2036: Load Never Completed. URL: http://.../projects/eom/widgets/LayerList/LayerListWidget.swf
Using firefox and chrome:
Error #2035
I have tried to clean the project and then modify the problematic .mxml, and I've also removed and re-added the module from the project.  I'm at a loss with this one, any help is appreciated!
RobertScheitlin__GISP
Martyn,
   So you are absolutely sure that the swf and xml for the problematic widget is in the widgets folder on your production server?
