Error #2004 - PopUpRenderer.as:259
3081
9
01-30-2012 03:07 AM
MagalyC_
Hello,
I have updated flexviewer + the eSearch widget (I am now with arcgis 10 :)) but I have this error message:
ArgumentError: Error #2004: L'un des paramètres n'est pas valide.
at ObjectOutput/writeObject()
at mx.collections::ArrayList/writeExternal()
at mx.collections::ArrayCollection/writeExternal()
at flash.utils::ByteArray/writeObject()
at mx.utils::ObjectUtil$/copy()
at com.esri.ags.webmap::PopUpRenderer/commitProperties()
at mx.core::UIComponent/validateProperties()
at mx.managers::LayoutManager/validateProperties()
at mx.managers::LayoutManager/doPhasedInstantiation()
at mx.managers::LayoutManager/doPhasedInstantiationCallback()
When i move my mouse on a result...
Any ideas?
Thx for help!
RobertScheitlin__GISP
Magaly,
   Which Adobe FLEX SDK are you building with (4.5, 4.5.1, 4.6)?
MagalyC_
I am using 4.5.1
Magaly,
   If you switch to 4.1 (which the Flex Viewer team uses for their release) you should be fine.
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
MagalyC_
It's worth with 4.1!
My debugger don't work anymore 😞
Magaly,
   Hmm... What do you mean your debugger stoped working. I use the 4.1 SDK always when dealing with the Flex Viewer and debug all the time...?
MagalyC_
I have captured the error.
Magaly,
    So it looks like you need to download the latest version of the Flash Player debugger:
http://www.adobe.com/support/flashplayer/downloads.html
MagalyC_
I know 🙂 But when i switch to 4.1, Eclipse told me to update my flash player. Since that, i have this error...
I will reboot my pc and reinstall this debugger...
We'll see...
Magaly,
   Yep, every time you change the version of Flash Player on your machine you also need to get the same version of the Flash Player Debugger.
