Error 1104 when changing initial extent in Flex 2.4 Viewer
1182
11-10-2011 05:07 AM
shildebrand
I downloaded the Flex 2.4 Viewer and got this message when changing the initial extent as suggested in the "getting started" page:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html
Application Error
http response status: 200
Fault code: Client.CouldNotDecode
Fault info: Error #1104
Fault details: null
I can send the config.xml file if needed.  Is anyone else getting this error?  I would appreciate any assistance.
Sam
RobertScheitlin__GISP
Sam,
   That error means that you introduced a syntax error into the xml file. So yes you need to post your changed xml file.
shildebrand
Sorry, the file wouldn't attach.........
<?xml version="1.0" ?>
// Read more about ArcGIS Viewer for Flex - http://links.esri.com/flexviewer
<configuration>
    <title>FPDWC Event Locations Map</title>
    <subtitle>a web mapping application for editing event locations</subtitle>
    <logo>assets/images/logo.png</logo>
    <style>
        <colors>0xFFFFFF,0x333333,0x101010,0x000000,0xFFD700</colors>
        <alpha>0.8</alpha>
    </style>
    <!-- replace the following url with your own geometryservice -->
        <geometryservice url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" />
        <!-- UI elements -->
        <widget left="10"  top="50"    config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/>
        <widget right="-2" bottom="-2" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/>
        <widget right="20" top="55"    config="widgets/MapSwitcher/MapSwitcherWidget.xml" url="widgets/MapSwitcher/MapSwitcherWidget.swf"/>
        <widget left="0"   top="0"     config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/>
        <map wraparound180="true" initialextent="12042000 -5619000 17795000 -952000" top="40" fullextent="-20000000 -20000000 20000000 20000000" top="40">
            <basemaps>
                <layer label="Streets" type="tiled" visible="true"
                       url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
                <layer label="Aerial"  type="tiled" visible="false"
                       url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/>
                <layer label="Topo"    type="tiled" visible="false"
                       url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
            </basemaps>
            <operationallayers>
                <layer label="Demographics" type="tiled" visible="false" alpha="0.5"
                       url="http://server.arcgisonline.com/ArcGIS/rest/services/Demographics/USA_Median_Household_Income/MapServ...">
                    <sublayer id="1" popupconfig="popups/PopUp_Demographics_BlockGroups.xml"/>
                    <sublayer id="2" popupconfig="popups/PopUp_Demographics_Tracts.xml"/>
                    <sublayer id="3" popupconfig="popups/PopUp_Demographics_Counties.xml"/>
                    <sublayer id="4" popupconfig="popups/PopUp_Demographics_States.xml"/>
                </layer>
                <layer label="Boundaries and Places" type="tiled" visible="false"
                       url="http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places_Alternate/..."/>
                <layer label="Fires" type="feature" visible="false" alpha="1.0"
                       popupconfig="popups/PopUp_Fires.xml"
                       url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0"/>
            </operationallayers>
    </map>
    <!-- widgets organized into widget containers that manage close/open etc -->
    <!-- supported layout property options: horizontal(default)|float|vertical|fix-->
    <widgetcontainer layout="float">
        <widget label="Bookmarks"         left="430" top="90"
                icon="assets/images/i_bookmark.png"
                config="widgets/Bookmark/BookmarkWidget.xml"
                url="widgets/Bookmark/BookmarkWidget.swf"/>
        <widget label="Find an address"   left="100" top="90" preload="open"
                icon="assets/images/i_target.png"
                config="widgets/Locate/LocateWidget_World.xml"
                url="widgets/Locate/LocateWidget.swf"/>
        <widget label="Louisville Police" left="590" top="280"
                icon="assets/images/i_police.png"
                config="widgets/Query/QueryWidget_Louisville_PoliceStations.xml"
                url="widgets/Query/QueryWidget.swf"/>
        <widget label="Search" left="80" top="280"
                icon="assets/images/i_search.png"
                config="widgets/Search/SearchWidget_Louisville.xml"
                url="widgets/Search/SearchWidget.swf"/>
        <widget label="Earthquakes (GeoRSS)" left="410" top="280"
                icon="assets/images/i_rss.png"
                config="widgets/GeoRSS/GeoRSSWidget.xml"
                url="widgets/GeoRSS/GeoRSSWidget.swf"/>
        <widget label="Draw and Measure" left="60" top="400"
                icon="assets/images/i_draw2.png"
                config="widgets/Draw/DrawWidget.xml"
                url="widgets/Draw/DrawWidget.swf"/>
        <widget label="Print" left="390" top="400"
                icon="assets/images/i_print.png"
                config="widgets/Print/PrintWidget.xml"
                url="widgets/Print/PrintWidget.swf"/>
        <widget label="My first widget"
                icon="assets/images/i_widget.png"
                config="widgets/Samples/HelloWorld/HelloWorldWidget.xml"
                url="widgets/Samples/HelloWorld/HelloWorldWidget.swf"/>
    </widgetcontainer>
</configuration>
Sam
   Your issue is that you entered top="40" twice.
just delete one of them.
shildebrand
Thanks!  I just thought that was a pixel distance for each extent (initial and full).
