Enhanced Splash Widget
2227
01-05-2012 06:33 AM
AshleyPeters
I have two issues I am trying to resolve.
The first is adding a title above the tabs, I've seen it done, but I'm just not sure where to make a change in the code.
The second involves removing the "don't show again" checkbox. I've removed it from the .xml, but it still appears. I'm making the assumption I need to remove some code from the .mxml file, I just don't know what needs to be removed.
Any help would be greatly appreciated! Thanks in advance!
Ashley
RobertScheitlin__GISP
Ashley,
   The title of the Enhanced Splash Widget is based on the label given to the widget in the main config.xml:
<splashpage label="ArcGIS Viewer for Flex" ...
To remove the don't show checkbox all you have to do is set the :
<disabledontshowoption>true</disabledontshowoption>
in the SlpashWidget.xml
AshleyPeters
I was making that much more difficult than it actually was. Thank you once again Robert, you are a great help!
