<value prompt="Example: 20" isvaluerequired="false" autosubmit="false" >gamefish_weight > '[value]</value><value prompt="Example: 20" isvaluerequired="false" autosubmit="false" >gamefish_weight > [value]</value>
All,
New Version now available:
Version 3.5.3 - 10/22/2013
* Fixed issue With preload="minimized" and the dropdownlists.
* Fixed issue with SubTypes and Domains assigned to subtypes.
* Fixed issue with text qualify userlists and the 'all' option.
Dongxing,
Well I have some bad news. It turns out that this is a documented ArcGIS Server issue. There was a bug logged NIM083086 and the Bug was rejected by the server development team "Known Limitation On Server End". The other user that had this same situation was told to remove the join or the Subtype field (not much of a resolution). I have added my name to the nimbus bug for this issue to see if it can be reopened and possibly get fixed without out a lame response from the development team, to just remove the join or the subtype field. I would recommend that you report the bug as well (make sure that you duplicate the issue using the OTB Search widget and not the eSearch, or they will just blame it on the custom widget).
I knew it only directly displays subtype value as number (code), can't automatically transfer code into description and display it, but it doesn't give a error, doesn't crash the searchThis is strange as I get error 400 when using the standard esri search widget when using a joined layer that has a subtype. Actually That is the test case I shared with esri when reporting this bug.
can't automatically transfer code into description and display itesris search widget does handle subtype fine as long as there is no join as well.
so I may have to use the 3.5 version eSearch instead of the latest version 3.5.3Why?.. In 3.5.3 Subtypes works and joined tables has worked way back since the 2.x version of the widget.
