Greg, I can take a look at your xml if you want me to.
<expressions> <expression alias="Troop Command" textsearchlabel="Search Troop Command:" isvaluerequired="true"> <values> <value prompt="Example: 153TC4" isvaluerequired="false" uniquevalsfromfield="TroopCommand" </value> <value prompt="Example: 153 TC" isvaluerequired="true" operator="AND">upper(TroopCommand) LIKE upper('%[value]%')</value> <value prompt="Example: 153 TC2" isvaluerequired="true" operator="AND">TroopCommand= '[value]'</value> <value prompt="Example: 153 TC3" uniquevalsfromfield="TroopCommand" isvaluerequired="true" autosubmit="false" operator="AND">TroopCommand = '[value]'</value> </values> </expression> </expressions>
<layer> <token/> <definitionexpression/> <enableexport>true</enableexport> <enableprintgrid title="Selected Troop Command(s)">true</enableprintgrid> <name>NYARNG UNITS</name> <url>http://ngnya0-gis-02:6080/arcgis/rest/services/UNITS/Units_Map2/MapServer/0</url> <expressions> <expression alias="Troop Command" textsearchlabel="Search Troop Command:" isvaluerequired="true"> <values> <value prompt="Example: 153TC4" isvaluerequired="false" uniquevalsfromfield="TroopCommand" autosubmit="false">TroopCommand = '[value]'</value> </values> </expression> </expressions> <graphicalsearchlabel>Use one of the graphical search tools to select Troop Command</graphicalsearchlabel> <spatialsearchlayer>false</spatialsearchlayer> <titlefield>TroopCommand</titlefield> <fields all="false"> <field name="UIC" gridfield="true"/> <field name="UNIT_NAME" gridfield="true"/> <field name="SITE_NAME" gridfield="true"/> <field name="SITE_CODE" gridfield="true"/> <field name="SiteNumber" gridfield="true"/> <field name="INSTNAME" gridfield="true"/> <field name="TroopCommand" gridfield="true"/> </fields> <links/> <zoomscale usegeometry="true" zoompercent="2"/> <autoopendatagrid>false</autoopendatagrid> <queryattachments>false</queryattachments> <relates/> <symbology> <picturemarkersymbol url="assets/images/i_camera.png" height="30" width="30" xoffset="0" yoffset="0" /> </symbology> </layer>
<operationallayers> <layer type="dynamic" label="DMNA Site" imageformat="png8" url="http://NGNYA0-GIS-02:6080/arcgis/rest/services/RealProperty/DMNA_Site/MapServer" visible="true"/> <layer type="dynamic" label="Units Map2" imageformat="png8" url="http://ngnya0-gis-02:6080/arcgis/rest/services/UNITS/Units_Map2/MapServer" visible="true"/> </operationallayers>
<relates> <relate id="1"label="Isolation Valves"enableexport="true"enableprintgrid="true"printtitle="Isolation Boundary Valves"> <fields all="false"> <field name="GDC.V_GDC_VALVES.ITEM_DESCRIPTION" alias="Valve Number"/> <field name="GDC.V_GDC_VALVES.HOUSING" alias="Housing"/> <field name="GDC.V_GDC_VALVES.VSIZE" alias="Size"/> <field name="GDC.V_GDC_VALVES.MAKE" alias="Make"/> <field name="GDC.V_GDC_VALVES.ADDRESS_TEXT" alias="Valve Address"/> </fields> </relate> </relates>
<expressions> <expression alias="Search by Park" textsearchlabel="Choose from the drop down list below"> <values> <value prompt="Example" uniquevalsfromfield="PARK" isvaluerequired="true">Lower(PARK) like Lower('%[value]%')</value> </values> </expression> <expression alias="Search by Park type" textsearchlabel=""> <values> <value prompt="Example: Hayward Shoreline">Lower(PARK) like Lower('%[value]%')</value> </values> </expression> </expressions>
