<field name='sqldatabasename."domain\owner_name".tablename.fieldname' alias="Field Name" gridfield="true"/>
I have already customized the widget with generous help from Robert (see here: http://forums.arcgis.com/threads/109735-eSearch-widget-combine-graphical-search-apply-buffer-and-int...). Now I want to do a little more. Is there a way to replace the drop down list in the graphical search tab with text? My widget only searches one layer and selects features within a buffer in one other layer. Currently, the dropdown shows both layers, based on what is in the configuration XML. True, the desired layer is on top and selected by default, but my customer does not want to see the other layer.
Thank you.
Mark
configSearchText[0].symbology = lyrSymbol;
fFeatLayer.renderer = new SimpleRenderer(lyrSymbol);
cboLayerText.visible=false;
selectionMethodText.visible=false;
* Return an array of unique field names.
Hi Robert, Is it possible to allow for multiple Vars in the search URL, I see you allow for one, R1..
Is there away to add a second Var, R2 ?
Warwick,
Where would the second var be used? Can you give me a more detailed example or workflow?
