Enhanced-Search-Widget-for-FlexViewer Part III
220657
776
04-30-2013 03:58 PM
RobertScheitlin__GISP
All,
   Here is a new thread to post questions and discuss the Enhanched Search Widget. The old thread was getting too long.
WarwickAttree
Robert, basically for a second portion of an And Clause..
Existing Syntax:
...esearch=Berea&slayer=3&exprnum=0&showdatagrid=true
To:
...esearch1=R1&esearch2=R2&slayer=3&exprnum=0&showdatagrid=true
This would enable a query like:
upper(ZONING_CODE) = upper('R1') and YEAR ='R2'
Warwick
Warwick,
   OK That is what I thought. I like the idea and will add it to the enhancement list.
Robert
WarwickAttree
Great, Thanks
Warwick,
   Here in the new GeoNet community there are new ways to help MVP like myself when we help you. You will see an actions menu at the bottom of each post if my post was helpful then click on the actions menu and choose "Mark as Helpful". Here is a link with other ways to help on the new GeoNet community.
How to help in the new GeoNet Forums.
Robert
WarwickAttree
Robert, the Action Menu, as I have it only has One Menu Item of : 'Report Abuse'
(IE11)
Warwick,
   OK, I am still trying to figure out when people have that ability and when they don't. So I quess the only thing you can do is click the "Like" link then. Thanks.
Robert
TerryHiggins
Let me apologize up front if this has already been answered - I'm having difficulty searching this forum for questions. I am trying to apply field name aliases to the fields that are presented in the popup window when I do a search with the Extended Search Widget. I'm using version 3.6 of Viewer for Flex Application Builder, and the most recent version of your Extended Widget. I want to list only certain fields within the popup and show their alias names.
I see where one might add field names under the spatial search layer but I am trying to do this for a regular layer. Can you advise how to perform this task?
Thanks in advance
Terry
RhettZufelt
MVP Notable Contributor
You should just have to put the <fields> info inside the <layer> tag for each specific layer and make sure you set an alias="desired name":
<fields all="false">
<field name="ZONING_CODE" alias="Zoning Code"/>
<field name="ZONING_NAME" alias="Zoning Name" sort="asc|1|string"/>
<field name="ZONING_TYPE" alias="Zoning Type"/>
</fields>
Look at example on page 1 and info on page 4 of the Enhanced Search Widget XML Configuration.pdf that Robert has supplied with the download of the eSearchWidget.  This should give you all the info you need.
R_
TerryHiggins
Thanks – Actually I tried that but it did not appear to work. This is what I have now – I want the fields to be listed for the Canyon Hill Cemetery Layer when I do the expression search on Last Name for example.
RhettZufelt
Is you FV or the cemetery layer visible somewhere?
R_
