<layer label="..." type="..." url="..." alpha="..." visible="..."> <sublayer id="1" popupconfig="..."> <widgetconfig name="esearch" file="path_to_subconfigfile" /> <widgetconfig name="identify" file="path_to_subconfigfile" /> <sublayer/> <sublayer id=".../> </layer>
Brent,
What version are you running (hold the Alt key and click on widget title)?
Brent,
Because you are not using the latest version 3.6.5, all I can do is tell you where to fix the issue in code (as I don't go backwards in releases to fix bugs). I will have this fixed for the 3.6 version. Let me know if you are using the source code and I will let you know where to apply the code fix.
if(searchResultAC.length > 0){ if(typeQ == "layer"){ if(isNaN(zoomScale)){ zoomAll(); }else{ if (map.scale > zoomScale){ map.scale = zoomScale; } map.centerAt(searchResultAC[0].point); } } if(ViewerContainer.urlConfigParams.showdatagrid != null){ if(ViewerContainer.urlConfigParams.showdatagrid == "true" && floatorfixed == "float"){ showGridResults(); } } }
