Enhanced Search Widget for FlexViewer 2.1
219076
767
10-25-2010 02:13 PM
RobertScheitlin__GISP
All Here is my next widget in the FlexViewer 2.1 series
Special thanks to Erwan Caradec for contributing to this code.
The Enhanced Search Widget extends the standard search widget with a floating data grid and a new spatial query w/buffering.
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
Alexandre,
   Here you go:
Don't forget to click the top arrow (promote) as shown below:
AlexandreHashimoto
Thank you Robert!
KenCarrier
Robert,
given the length of this post I started a new thread where I have asked a question about the enhanced search widget. I also noticed the MVP program has started up again.
Would be happy to give you the points
http://forums.arcgis.com/threads/53043-Enhanced-Search-Widget-version-2.5.1.4-Link-Fields-in-Grid?p=...
KenCarrier
Robert,
Here is another post in the correct forum regarding subtypes.
http://forums.arcgis.com/threads/53053-Enhanced-Search-Widget-version-2.5.1.4-Subtypes-Not-Displayin...
Once again will gladly give points. Thanks for all the help!
DeanSeales
Is there a way to add a static link that is not associated to a particular field: the same link pops up no matter which individual feature is queried?
I've tried several ways but keep getting  nothing.
Thanks for any  help.
Dean,
   The way I have this current version now there is not a configuration setting that you can make to have an image show in the results with out being tied to a field.
ChristopherBlinn1
Hey Robert,
Any thoughts of tying in some of the auto-complete functionality into the search text box? I am going to start working on the uncompiled code and see what I can come up with. Has anyone mentioned wanting this functionality, or have you looked into it already? Don't want to reinvent the wheel if I do not have to.
Chris B.
Chris,
   No I don't have any plans for that at all. My code base for this widget is already much more than I would like it to be.
ChristopherBlinn1
I understand Robert, it is a fantastic widget already!
If we come up with a solution would you like me to send you the source code?
Chris,
   Sure I would like to see what you come up with.
