//Add this function private function mapResizeHandler(evt:Event):void { if(myfloatdg){ myfloatdg.y = map.height + Number(ViewerContainer.getInstance().mapManager.top) - myfloatdg.height; myfloatdg.x = 0; } } //Add this to the init function map.addEventListener(ExtentEvent.EXTENT_CHANGE, mapResizeHandler);
upper(ZONING_CODE) = upper('[value]')
<layer> <definitionexpression></definitionexpression> <enableexport>true</enableexport> <name>Planning Apps</name> <url>http://baltimore/ArcGIS/rest/services/ATLAS_Plan/ATLAS_Plan_Dynamic/MapServer/17</url> <expressions> <expression alias="Planning Applications" textsearchlabel="Enter Planning Application Number [ Example: 03/00981/FUL ]:">UNISDELIVE.UFRM_DCAPPL_POLY.REFVAL LIKE ('[value]%')</expression> </expressions> <graphicalsearchlabel>Use one of the graphical search tools to select Planning Application</graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer> <titlefield>UNISDELIVE.UFRM_DCAPPL_POLY.REFVAL</titlefield> <linkfield linkprefix="" linksuffix=""></linkfield> <fields all="false"> <field name="UNISDELIVE.UFRM_DCAPPL_POLY.REFVAL" gridfield="true"/> <field name="UNI73LIVE.PLAN_APPS.DCAPPTYP" gridfield="true"/> <field name="UNI73LIVE.PLAN_APPS.DCSTAT" gridfield="true"/> <field name="UNI73LIVE.PLAN_APPS.DATEAPRECV" gridfield="true" dateformat="DD/MM/YYYY"/> <field name="UNI73LIVE.PLAN_APPS.ALTREF" gridfield="true"/> <field name="UNI73LIVE.PLAN_APPS.KEYVAL" gridfield="false" hyperlinkgridfield="false" hyperlinkaliastext="UNI73LIVE.PLAN_APPS.KEYVAL" linkprefix="http://planning.southend.gov.uk/PublicAccess/tdc/DcApplication/application_detailview.aspx?caseno=" linksuffix=""/> </fields> <linkfield linkprefix="http://planning.southend.gov.uk/PublicAccess/tdc/DcApplication/application_detailview.aspx?caseno=" linksuffix="">UNI73LIVE.PLAN_APPS.KEYVAL</linkfield> <icon isfield="true" iconsuffix="" iconprefix=""/> <zoomscale usegeometry="false">5000</zoomscale> </layer>
<layer> <definitionexpression></definitionexpression> <enableexport>true</enableexport> <name>Planning Apps</name> <url>http://baltimore/ArcGIS/rest/services/ATLAS_Plan/ATLAS_Plan_Dynamic/MapServer/17</url> <expressions> <expression alias="Planning Applications" textsearchlabel="Enter Planning Application Number [ Example: 03/00981/FUL ]:">UNISDELIVE.UFRM_DCAPPL_POLY.REFVAL LIKE ('[value]%')</expression> </expressions> <graphicalsearchlabel>Use one of the graphical search tools to select Planning Application</graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer> <titlefield>UNISDELIVE.UFRM_DCAPPL_POLY.REFVAL</titlefield><linkfield linkprefix="" linksuffix=""></linkfield> <fields all="false"> <field name="UNISDELIVE.UFRM_DCAPPL_POLY.REFVAL" gridfield="true"/> <field name="UNI73LIVE.PLAN_APPS.DCAPPTYP" gridfield="true"/> <field name="UNI73LIVE.PLAN_APPS.DCSTAT" gridfield="true"/> <field name="UNI73LIVE.PLAN_APPS.DATEAPRECV" gridfield="true" dateformat="DD/MM/YYYY"/> <field name="UNI73LIVE.PLAN_APPS.ALTREF" gridfield="true"/> <field name="UNI73LIVE.PLAN_APPS.KEYVAL" gridfield="false" hyperlinkgridfield="false" hyperlinkaliastext="UNI73LIVE.PLAN_APPS.KEYVAL" linkprefix="http://planning.southend.gov.uk/Publ...ew.aspx?caseno=" linksuffix=""/> </fields> <linkfield linkprefix="http://planning.southend.gov.uk/Publ...ew.aspx?caseno=" linksuffix="">UNI73LIVE.PLAN_APPS.KEYVAL</linkfield> <icon isfield="true" iconsuffix="" iconprefix=""/> <zoomscale usegeometry="false">5000</zoomscale> </layer>
<field name="SURVEYS" alias="Surveys" hyperlinkgridfield="true" hyperlinkaliastext="View Surveys" linkprefix="http://maps.clemson.edu/culandmanagementv2/" linksuffix="" gridfieldonly="false"/>
