Robert, I would like the user to only be able to search one or two layers defined in the xml. Build a buffer, then find seperate point locations defined in the xml spatially within the buffer.
For instance the user would select to search a city or neighborhood layer. The widget zooms to that location from the selection results. The user can then build a buffer, then spatially find point locations from seperate layers defined in the XML such as Hospitals, Points of Interest, etc.
The xml already lets you specify which layers can be located spatially, what I would like is to filter out or limit the layers that can be searched on the text input page. hth...thanks, Mark
