Enhanced Search Widget for FlexViewer 2.1
219179
767
10-25-2010 02:13 PM
RobertScheitlin__GISP
All Here is my next widget in the FlexViewer 2.1 series
Special thanks to Erwan Caradec for contributing to this code.
The Enhanced Search Widget extends the standard search widget with a floating data grid and a new spatial query w/buffering.
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
Dustin,
   Did the latest zip not contain the i_save.png?.. Strange... I uploaded again making sure the special character is gone and the i_save.png is definitely in there.
ErwanCaradec
Thanks Robert !
little problem, the new assets are missing in your démo site :
http://gis.calhouncounty.org/IdentExample/index.html?config=config-eSearch.xml
Erwan
Erwan,
   Thanks for the heads up on that. Hope you like the other changes in this release.
ErwanCaradec
This is really a great Job !
I like very much the multi field selection in the search text too.
There's only a little problem in the spatial search, color&alpha controls doesn't change the buffer graphics apperance.
Thanks again !!
Erwan
DustinKosmach1
Im getting error 2036 with I try to open the widget.  I am getting this error on my map and also on the ESRI 2.2 map.  Everything has been set up according to the readme.
Dustin,
   Try opening the SearchWidget.xml file in internet explorer or so other web browser to see if it is not well formed xml.
DustinKosmach1
I tried doing that and it opens with out error.  I tried copying the xml text from the zip, from the browser window, deleted comments, and nothing is working.  The most aggrivating part is that there is no description.  Just error #2036.  If I click ok and try it again, I just get a gray box with an OK button.
Dustin,
   Have you tried downloading a fresh copy and overwriting all the current files you have then without changing anything test it.
DustinKosmach1
Im in the process of doing that right now.  I dont have much configured, so I am just starting from scratch. Ill let you know.
JohnGregorovic
Thank you again for all your hard work updating this widget.  I have updated my sites with v2.2
Adding the ability to query different fields per layer, adds  a whole new layer of functionality.
As you can see by this collision map, now I can search collisions by address, type, weather conditions and road conditions.
http://maps.cityoftulsa.org/flexviewer-Police_Collisions/
Also the new spatial search tab works great, once you realize you have to do a preliminary search first, but I really like that.  It's easier to explain to a novice.
