Enhanced Map Switcher Widget
13946
37
10-27-2011 12:38 PM
JeffreyUtter
Robert........
I really like this widget, but I have 2 issues with it.
First, the widget causes a white line across the map. It's not there if I remove the widget.
Second, the labeling dropdowns from the top toolbar widgets are covered up from the basemap/Enhanced Map Switcher Widget. Again, if I remove the Enhanced Map Switcher Widget, the dropdown labels can be seen over the top of the basemaps.
Please advise.
Jeff
RobertScheitlin__GISP
Josh,
   To use Bing maps you need to see the documentation on using them here:
http://help.arcgis.com/en/webapps/flexviewer/help/01m3/01m30000000p000000.htm
Scroll down and look for the "Attributes specific to Bing Maps" Headding
JoshThomas
Thanks for your reply!  This is good information that I was missing.  I will try to configure it this way and will let you know if I'm successful or not.
Josh,
JoshThomas
Robert,
I followed the instructions in the documentation to set up the Bing maps in our compiled viewer.  It worked great!  I wouldn't have known where to start piecing all of the steps together, so thanks for your help!
Josh
Josh,
RobertShepard
Hi Robert,
(Sorry to bother you with this inquiry last week on the comments section of the widget).
I was hoping that you might still have the last 2.4 version of the widget available.  If so, could you please direct me to the download for that?
Thank you for your help and for your time.
-Rob Shepard
Robert,
  Sure here it is. I only keep the old compiled versions though.
RobertShepard
Thanks so much!
DeanSeales
Hello Robert,
is it possible for you and dgalluzzo to collaborate? Your basemap fader is awesome and his Enhanced Map Switcher (http://www.arcgis.com/rc/item.html?id=c720fb45e752402d978c2fdbe4259746) is great. It would be awesomely great if those two can be combined.
As always...thanks for those great widgets!
Dean,
   This is all going to change in 3.0 as you will have the option to choose a basemap from a thumbnail basemap gallery.
http://resourcesbeta.arcgis.com/en/help/flex-viewer/concepts/01m3/01m30000003w000000.htm
trannoyronan
Dear Robert,
i am using the new version of the eMapSwitcher 3.0 and i wondering if it is possible to use a tag to define the thumbnails for non esri basemap (defaultbasemap),
it will be better than to modify the  code
thank
Trannoy,
   Sure that is defined in the Main Config.xml file by adding the icon attribute:
            <layer label="Streets" type="tiled" visible="true"  alpha="1" icon="assets/images/basemap_streets.jpg"
                        url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
Don't forget to click the top arrow (promote).
Follow the steps as shown in the below graphic:
