enhance layer list - exclude layers?
3667
10-08-2014 05:44 PM
AlistairFox
this widget is cool, http://www.arcgis.com/home/item.html?id=58d9bb5693c94918a3934781d7234d18  however it doesn't seem to exclude the layers I set in the widget. Any ideas? is this a bug. They are editable feature layers, is that a limitation?
Cheers
Alistair
RobertScheitlin__GISP
Allistar,
   Because you are using a featurelayer and not a dynamic layer you should not include the layer id in the exclude:
<excludelayer mapservice="Section8 Non Defence users"/>
Alistair,
   Can you post your xml configuration for excluding those layers?
AlistairFox
eLayerList config below and then an example of the 1st layer being reference from the config.xml
<?xml version="1.0" ?>
<configuration>
    <labels>
        <visibilitylabel>Layer Visibility</visibilitylabel>
        <expandall>Expand All Layers</expandall>
        <collapseall>Collapse All Layers</collapseall>
        <zoomtomakevisible>Zoom To Make Visible</zoomtomakevisible>
    </labels>
    <tocsettings>
        <collapselegends>true</collapselegends>
        <disablezoomtomenuoption>false</disablezoomtomenuoption>
        <expanded everything="false">true</expanded>
    </tocsettings>
    <excludegraphiclayers>true</excludegraphiclayers>
    <excludebasemaplayers>true</excludebasemaplayers>
    <usenewesridescription>false</usenewesridescription>
    <excludelayers>
        <excludelayer mapservice="Section8 Non Defence users">7</excludelayer>
        <excludelayer mapservice="Section7 Security and Safety Considerati">6</excludelayer>
        <excludelayer mapservice="Section6 Design, Traffic and Property Co">5</excludelayer>
        <excludelayer mapservice="Section5 Engineering Considerations">4</excludelayer>
        <excludelayer mapservice="Section4 Environment &amp; Heritage Consider">3</excludelayer>
        <excludelayer mapservice="Section3 Zone or Master Planning">2</excludelayer>
        <excludelayer mapservice="Section2 Technical">1</excludelayer>
        <excludelayer mapservice="Section1 AirFields and Aviation">0</excludelayer>
    </excludelayers>
</configuration>
<layer type="feature" label="Section8 Non Defence users" url="https://xxxxxxxxxx/arcgis/rest/services/Land121/Section_Considerations/FeatureServer/7" popupconfig="popups/PopUp_6.xml" mode="onDemand" definitionexpression="SiteNumber = 21" visible="false"/>
Allistar,
AlistairFox
thanks. App builder doesn't allow you option to remove the layer id's. so manual edit of config file works.
thanks
