Embedding the Viewer into a asp.net application
1283
03-20-2012 12:56 PM
MattPohl
Hi there,
I was hoping to get a starting point and or some direction on embedding the flex viewer into a asp.net application. I have created my flex viewer application and it works great. I have created a testing website using Visual Studio Web Developer, but am stuck trying to figure out how to embed the flex viewer app into the website. I am by no means a web programmer and don't pretend to be, but with a little help I am sure I can get this. I know it can be done because I have read posts where people reference this setup. For now I am just looking to do it locally, and don't need to access it outside of our network. Any help would be greatly appreciated.
Matt
RobertScheitlin__GISP
Matt,
   See if this helps:
http://forums.arcgis.com/threads/6275-ASP.Net-Login-Wrapper-and-Flash-Cutoff-Problem
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote) as shown below:
Matt,
   See if this helps:
MattPohl
Thanks Robert for the reply back. After a little bit of tweaking, I think I got it to work, at least locally. I am sure it will be another hill to climb when I try it live. Your help is always appreciated.
~Matt
