eMapSwitcher - Fader
1680
6
06-25-2012 03:08 AM
JamesEdge
I am using 2.5 uncompiled version. In my config.xml I have set my 2nd basemap (street) to open by default but the fader slider button is positioned at the 1st basemap (ortho). How do I set it so that the slider button starts at the 2nd basemap? Thanks.
MarcCavallaro
Hi James, did you ever figure this out?  I'm attempting to do the same.
Thx
RhettZufelt
MVP Notable Contributor
Very bottom of the eMapSwitcherWidget.mxml:
  <s:HSlider id="fader" left="10" right="10" mouseFocusEnabled="false"
       minimum="1" maximum="{basemapList.length}" bottom="5"
       snapInterval="0.01" liveDragging="true" enabled="true"
       showDataTip="false" value="2" change="faderFade(event)"
       skinClass="widgets.eMapSwitcher.BasemapFaderSkin"/>
will make the slider start out on the second basemap.
R_
RobertScheitlin__GISP
All,
   This is not an issue in the latest release.
MarcCavallaro
All,
Hi Robert,  Can you please confirm that it works with <showthumbnails>false</showthumbnails>.  I'm not getting the desired results.
Marc
Marc,
   Thanks for letting me know I will be releasing a fix for this very soon.
Marc,
   Verson 3.0.3 now fixes that issue.
