eLocate Tool question
4797
7
08-05-2015 09:37 AM
MardiGullage
In the eLocate widget, is there any way to control the level of zoom on a lat/long point? It zooms in beyond the resolution of my base map. And is there any way to accommodate postal codes in the address fields? At the moment, it only displays the first three characters.
RobertScheitlin__GISP
Mardi,
  Right now this is all that is being returned from the locate results using http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer
  Address = "74 E White Hills Rd"
  City = "St John's"
  CountryCode = "CAN"
  Loc_name = "CAN.StreetAddress"
  Match_addr = "74 E White Hills Rd, St John's, Newfoundland and Labrador, A1A"
  Neighborhood = (null)
  Postal = "A1A"
  PostalExt = (null)
  Region = "Newfoundland and Labrador"
  Subregion = (null)
Mardi,
  Sure you can control the zoom scale be adding the zoomscale property to the xml (by default the widget uses 10000 as the zoomscale).
<zoomscale>24000</zoomscale>
It appears that I neglected to document this.
I don't understand this portion. Can you provide more info and/or screenshot:
MardiGullage
Thanks for the quick response! The postal code is the Canadian version of a zip code. The format is alternatng letters/numbers and is six digits long with a space. i.e A1C 5S7 . At the moment addresses in Canada appear like this:
Mardi,
  City = "St John's"
  CountryCode = "CAN"
  Postal = "A1A"
  PostalExt = (null)
  Subregion = (null)
MardiGullage
Oh well. It's not really important for our puposes at this time, but in a future incarnation, it would be great to have. Guess the server is just not set up for handling postal codes. Thanks!
Mardi,
Glad to help. Now it is your turn to help the community by marking this question as answered. All you have to do is click the "Correct Answer" link (the one with the little green star) on the post that provided the answer for you. If the answer was not provided by one of the responders then you can mark any of the replies that you received as helpful by clicking on the "Actions" menu and choosing "Mark as Helpful"
Mardi,
   Hmm. You marked your own reply as the correct answer. If that is what you intended to do thats fine, but were none of my replies at least helpful?
MardiGullage
Sorry. My bad. I have changed it. You were very helpful!
