Elevation Profile Widget Error
3609
6
01-28-2014 06:00 AM
BrentFoster
I'm getting the error 'The server returned and error:  Error in handling operation GetElevations' now when I use this widget.  Has there been any changes to the elevationsSOE web services that this widget consumes? I tried out a couple of them without success.
http://sampleserver6.arcgisonline.com/arcgis/rest/services/Elevation/WorldElevations/MapServer/exts/...
MaironBonzanini
Hi bro..
Ur version flex? send .xml .swf..
att,
BrentFoster
Using Flex Viewer 3.5, out of the box no modifications.  Was working fine a few weeks ago, suddenly getting these errors when trying to use.  I've made no changes to the Flex Viewer in that time.  I tried it out on a fresh download of the Flex Viewer, with no changes whatsoever, same errors.  I'll test outside of the office, maybe some type of internal company firewall issue?
BrentFoster
Working properly now, I made no changes on my end.  Must have been a elevation service issue.
DanielOchoa
bfoster266
The widget you are using- is based on the code/ the one found here?:
http://www.arcgis.com/home/item.html?id=482f87d3232543eaade769665d0856a3
On a whim I tried it and it just crashes the browser. I'm using 3.5, like you are. Can you tell me if this is the one you are using or is it a different one? Could you possibly post the widget you are using here?
~ D
BrentFoster
by Anonymous User
Not applicable
After drawing a line I encounter the following errer: "A problem occurred while parsing and charting the returned elevation data. Error #1006: findStyleDeclaration is not a function" .... Anyone else seeing this or have a possible work-around? Better yet, anyone have the uncompiled code I could add into my Flash Builder project? Thanks!
