eDraw Widget Bug?
5717
19
09-28-2012 01:25 PM
JamesKo
I've noticed if you don't select the 'Show Measurement' checkbox and you edit the graphic, the measurement in the contextmenu does not get updated. Can anyone confirm this?
Thanks in advance.
RobertScheitlin__GISP
James,
   This is not an issue in the 3.0.1i version.
JamesKo
Hi Robert,
I downloaded the newest version and it still wasn't working for me, specifically, when I move a vertex on a polyline. Then I noticed in the calculatePolylineLengths function that the wkid I was using wasn't dealt with properly in the 'if else' statement.
I got it working now...
Regards,
James
GeorgeHaskett
Rob,
I just went through the latest two version of the eDraw widget.  In both cases my icons/Labels for the Bold and Underline buttons failed to appear as usual.
Haskett
George,
   You should get out of the habit of using existing threads that do not pertain to your issue and start new threads for you issues. This helps both me and those who follow these threads to find the answers they are looking for better.
   The last two versions of the eDraw do not use an icon for the bold or underline buttons... Not sure what you are seeing...
GeorgeHaskett
Rob,
In the past you mentioned to use existing threads if applicable, which I try to do.  I'm sorry I must have misunderstood you.
As for my previous question, the thread seemed fitting.  I will try to explain it better.  Maybe I should have used the term label without the term icon.
Normally you have a 'B' label for Bold, and 'I' label for Italized and a 'U' label for the Underline button.  The past two versions failed to bring up the 'B' and the 'U' labels.  The older version pulled them in automatically (B, I, U).  Is this something I need to fix on my end with the compiled widget mxl file?
This has not happened to me before when using the older widgets.  I can send you a screenshot if need be.
This is in regards to the Show Measurements portion of the widget.
Haskett
George,
   Yes please attach a screenshot and your eDrawWidget.xml
Here is screenshot of the latest version on my live preview site:
[ATTACH=CONFIG]21701[/ATTACH]
GeorgeHaskett
Rob,
Okay, attached is a screenshot of my eDraw GUI plus my xml file.
Haskett
George,
   Are you using the source code for the viewer or the compiled version?
GeorgeHaskett
Rob,
I should be using the compiled version, that's what I usually grab.  Did I grab the wrong one?
