EditWidget (Viewer for Flex 3.4) - Prepopulate fields by code ?
1066
07-18-2013 01:35 AM
GuillaumeROUSSEL1
I use the EditWidget of a viewer for flex 3.4.
In the editor, I try to prepolutate an address field by code.
For instance :
- getting x/y of the mappoint clicked by the user => OK
- reverse geocoding for this point => OK, address is found
- affect the address to the address field (seem OK)
=> editor.attributeInspector.activeFeature.attributes["address"] = "reverse geocoding address found";
The problem is the editor is opened BEFORE reverse geocoding is finished.
The value of the address field seem correctly changed (because if I validate, the record in database own the correct address), but the field display is not filled for the user.
I try a lot of things :
- bindable var for the address
- editor.attributeInspector.activeFeature.attributes["address"] = "reverse geocoding address found";
- editor.attributeInspector.activeFeature.validateNow();
- editor.attributeInspector.activeFeature.validateProperties();
- editor.attributeInspector.activeFeature.refresh();
- editor.attributeInspector.refreshActiveFeature();
- editor.validateNow();
Unfortunately, no way to refresh the display !!!
Do you have any idea to correct this point ?
In anticipation, thank you for help !
Guillaume
GuillaumeROUSSEL1
Another solution would be to add a new icon near the address field.
After the editor windows is opened, a click on this icon would prepopulate the address field with the address found by the reverse geocoder (like the calendar icon)
According to you, is this a good solution ?
If yes, how to start ?
Thank you !
Guillaume
