Editing the Locator Widget
3241
8
03-13-2013 03:08 PM
NeilMillward
I would like to add an example of what people should type into the street box such as "300 E Chapman Ave" so that they type in the correct format to locate the address.
On the standard locator widget there is a label that says "Enter the Address". I would like to be able to modify this to say " Enter the Address eg: 300 E Chapman Ave" but I cannot find where or how to do this. I have looked at the code in the LocateWidget.xml file but could not find this text.
Any help would be appreciated.
RhettZufelt
MVP Notable Contributor
Thanks Anthony.
I am pretty new to this. There doesn't seem to be anywhere in the application builder to do this. Do I just need to add these edits to the LocateWidget.xml.
This is my current file.
?xml version="1.0" ?> <configuration>     <labels>         <addresstitle>Enter the Address eg: 300 E Chapman Ave</addresstitle>     </labels>         <locator>http://civ-gisapp-vm1:6080/arcgis/rest/services/AddressPointLocator/GeocodeServer</locator>     <usesearchextent>false</usesearchextent>     <minscore>10</minscore>     <zoomscale>10000</zoomscale> </configuration>
I don't use app builder, but you should be able to add it in the LocateWidget.xml.
R_
RhettZufelt
Here are the available "labels" for the locate widget.  Can be found in the VewerStrings.properties file:
########## Locate Widget
locateSubmitLabel=Locate
addressLabel=Address
coordinatesLabel=Coordinates
addressTitle=Enter the address
coordinatesTitle=Enter the coordinates
xLabel=Longitude (X)
yLabel=Latitude (Y)
locationsLabel=Locations found:
bingCulture=en-US
requiredFields=Required fields:
requiredField=Required field:
deleteResultTooltip=Delete result
resultScoreText=Score:
bingResultConfidenceText=Confidence:
R_
NeilMillward
Thanks Rhett. Where would I find the ViewerStrings.properties file?
RhettZufelt
Assuming you are using the source code, would be in the locale/en_US folder in FlashBuilder package explorer.
R_
NeilMillward
I am using the compiled version. I don't have FlashBuilder.
AnthonyGiles
Honored Contributor
Neil,
If you are using the out of the box locator widget you can use the addresstitle tag under labels to provide what ever example you would like, see:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Locate_widget_tags/01m30000000r...
Regards
Anthony
E.g.
<labels>
   <addresstitle>Enter House Number & Street Name e.g. 300 New Street</addresstitle>
</labels>
NeilMillward
Thanks Anthony.
<configuration>
</configuration>
RhettZufelt
Thanks Anthony.
R_
NeilMillward
Thanks Rhett this worked.
