Edit Widget Problems - XML not being honored.
764
01-05-2012 09:34 AM
PatrickMullen1
The edit widget is not honoring the settings in the xml configuration. I have set it up so users can only update attributes.
However, when clicking on a feature after the popup is created, the vertices show up and I am able to edit them.
I have confirmed that the xml configuration updateGeometry is being read but somewhere along the way the widget forgets the property set and enables editing of the vertices.
Any Ideas?
Patrick
deleted-user-RjoC4IOGTpoH
I am having the same exact issue. Users are able to edit the vertices of features even though only edit attributes is enabled in the XML.
