Edit Widget - excluding attributes
1195
01-23-2012 11:34 AM
JonathanRoberts
Is there a way to exclude attributes in layers that are editable?  I only want select fields in a layer to be editable, not all of them - is that possible?
Thanks!
Jon Roberts
Univ of Missouri-Columbia
RobertScheitlin__GISP
Jon,
   Sure when you publish your FeatureService you can mark certain fields in a layer as read-only in the MXD and that caries over to the FeatureService.
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
JonathanRoberts
Thanks Robert!  It would be nice if the widget itself could control that, but I won't complain.
Jon,
   Glad to help.
